Exar-Kun »
https://forums.nicoclub.com/exar-kun-u1725.html
Sat Oct 18, 2003 9:05 pm
a good rule of thumb is to keep the inner edge of the wheel less than 5mm closer to the stock strut, using the offset calculator in the FAQ...(for the front) for the rear, you can go as high as 12mm closer.
you can fit a really wide wheel on 240's, but most require fender flares to fit properly(since the offset must be low to clear suspension peices)
the widest wheel I like to see is 8" wide on the front, maybe a 27mm offset or so, and a 9-9.5" rear, 32mm offset or a bit less maybe.-chet
