ok I THINK to much......... or have to much TIME.........
projectka-t
Car: 1995 nissan 240sx
Ok...... I was thinking of a way to get around the drilling of the oil pan and running 1-2 quarts low..... so im doing a full KA-T build and i was looking at the block and was thinking about drilling and tapping a hole in the block above where the oil pan mounts to get above the full oil level. SO ........ Am i smoking crack? or would this work ?
214kka-et240sx
Car: nissan s13 silvia
you mean were like a sr would have it then yes it will work
projectka-t
Well not to sound like a noob but hey i am ..... i have never seen a sr up close... but was just currious.
projectka-t
Does anyone have a clear pic. of the oil inlet into the block ? i would much appreciate it !
nissanfanatic
Car: 1992 Nissan 240sx SE
I run a full 4 quarts in my setup just fine...
projectka-t
I have talked to alot of people and some say "I run fine full" and others say "i run 1-2 quarts low" and at this point with the block all open i was just trying to prevent any future porblems! I just had no idea that the sr was "pre-drilled" for the outlet on the turbo.
WDRacing
Sr and RB both use a block style return. If you tap the pan in the correct position you will be fine.
WD
wild_maxx
Car: 90 TT pearl yellow z32
i run a full 4 quarts of oil and have had no problems for the 3 weeks that i got to drive it. ( cracked ring lands)
:: orion ::
Car: '96 240SX, with KA-T @ 12psi...
For allt he newbs that may read this: DO NOT run your motor 1-2 quarts low...you'll develop rod knock and come back here complaining and saying" I should've went with an SR like my buddy told me to..."
And I plan to tap my block next time the motor it's out (for a "spring cleaning"). The SR has a thick AL spot that you can drill/tap - The KA's iron block will most likelly be too thin to tap (you'd only get a thread and a half)...so brazing a bung on there may be the way to go.
We'll see...I may try to weld one onto my spare block, to see fif it will stick.
- Brian
DRIFTEADOR
:: orion :: wrote:For allt he newbs that may read this: DO NOT run your motor 1-2 quarts low...you'll develop rod knock and come back here complaining and saying" I should've went with an SR like my buddy told me to..."
thats what i thought too. this looks like enough space for th oil too drain properly
hard to see, sorry for the ****ty pic, but there is about 1.75" from the top of the pan w/ 1 gallon of water in there. the pick up shouldn't make a difference.
:: orion ::
Hehehehe...a line output converter and a rubber mallet...awesome.
That's a good pic, shows the capacity quite well.
Thanks.
- Brian
DRIFTEADOR
hehe..i work with what i have
