spooled240 »
https://forums.nicoclub.com/spooled240-u54828.html
Sat May 30, 2009 3:32 pm
So long story short, I whacked my driver's rear wheel on a curb about a month ago REALLY hard and broke my rear lower control arm(LCA) and my toe arm:
So i got a replacement rear LCA and a replacement toe arm and the driver's rear wheel is still kinda whacked. It drives smooth and straight but my camber is adjusted all the way neg and my toe is adjusted all the way in and my wheel is perfectly straight up and down with a small amount of toe in. Something is obviously still messed up and I'm not sure if I should replace the other suspension arms. I measured my rear upper control arm (RUCA) bolt to bolt and it matches up with the other side. Could I have bent something on the sub-frame? Or the cast iron spindle? I dunno but maybe someone with some insight or similar experiences can shed some light.
**Please don't turn this thread into a rant about street drifting and s***, I learned my lesson. I don't care if you guys shoot the s*** or whatever but please no arguing about whose d!ck is bigger and NO FORUM f*****
