ok, i just lowered my y33. what do i need to do for front and rear alignment????
antbo
just like the topic says. what should i specify at an alignment shop??? the rear toe is crazy lookin, do i get that straightened out for more tire life..etc?? and can someone refer me to an alignment shop that specializes in these type of situations in san diego?? thanks
Q_SHIP
Car: 1999 Q45T with a billion miles.
Rear tow? Or do you mean camber?
If it is camber, not a whole lot can be done on a Y33. But the tires suprisingly don't wear that bad like that.
Q45tech
When you lower [or just from age impact stress] it is frequently necessary to replace suspension arms [squished bushings] or use aftermarket adjustable specialty arms.
The costs of lowering is not just for the springs and shocks.............but for all the suspension parts you must design.
Most people lower for looks so they skip the handling tire wear issues that come from lowering.
When I see a lower vehicle I almost always know the owner could care less about functionality.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
rear camber can be tweaked a little.. Main thing you need readjusted is the toe (which is a normal alignment). An extra degree of camber with the SAME toe angle (adjusted) wont wear tires. Its when lowering the car that increases camber AND toe that causes it.
Falkdesigns
Car: 1998 Q45t ~ EXE
They should be able to adjust everything to perfect except camber, which will be negative, but I'm pretty sure you want that anyhow.
I'm not sure if Auto Fashion has an install shop, but if they don't I'm sure they can point you to an alignment shop that deals with lowered cars.
I missed the other replies. Yes, you CAN lower a car, and ride with negative camber without killing your tires. My tires have just over 1 year and the wear is even all the way across, and I've got about -2 degrees in front, and close to -3 in the back. Toe and Caster are most important.
Qproject
what exactly is "TOE" ? I understand that "camber" is the angle at which the wheels-tires fall in or out.
but what exacty does "toe" involve? is it how "left" or how "right" the wheels-tire end up turning ?
elwesso wrote:rear camber can be tweaked a little.. Main thing you need readjusted is the toe (which is a normal alignment). An extra degree of camber with the SAME toe angle (adjusted) wont wear tires. Its when lowering the car that increases camber AND toe that causes it.
Falkdesigns
Toe is like if you have duck feet, your feet are parallel, or your toes point in towards each other.
Qproject
nice
what about "caster" ?
Falkdesigns wrote:Toe is like if you have duck feet, your feet are parallel, or your toes point in towards each other.
antbo
thanks for the advice guys. i was trippin out when i saw the toe all contarted looking. i guys its nice to know that even though i have camber, its not so bad on the wear, but i def gotta fix the toe. ill try to post pics of my car, its just TOO dirty. i got a wash it first.
so toe and caster, should i specify what i want???
Falkdesigns
No, just tell them to put it to OEM range specs. Of course they'll probably say they can't get the camber into range, but you already know that. And honestly, most OEM camber range is from + to - 2º anyhow.
edit
Here's a great little site that will help explain toe, caster and camber
http://www.ozebiz.com.au/racet....html
antbo
ok, thanks falk
antbo
Falkdesigns wrote:No, just tell them to put it to OEM range specs. Of course they'll probably say they can't get the camber into range, but you already know that. And honestly, most OEM camber range is from + to - 2º anyhow.
edit
thats funny, i was actually looking at that earlier today
elwesso
2007 BMW M Coupe
Caster is also not adjustable without adjustable tension rods.....
Just get your usual alignment and tell them to get the toe PERFECT, and everything else will sort of take care of itself (since its not adjustable anyway)
Qproject
what movement does CASTER refer to?
elwesso wrote:Caster is also not adjustable without adjustable tension rods.....
elwesso
2007 BMW M Coupe
if your loooking at the side of the car it refers to how far left or right the wheel is positioned in the wheel well....
Q45tech
1 degree of excess [above 0.75] negative camber can materially affect the braking distances..................it is not just tire wear alone one has to worry about. More critical on front than rear.
The trapezoidal shape of patch overheats the inner portion thus the increase inner wear.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Q45tech wrote:When I see a lower vehicle I almost always know the owner could care less about functionality.
IQ correlates 100% with deviation from OEM ride height!
Seems to work for the bubbas with the jacked trucks on the street and for the speed bump plowing crowd.
"Member's standards vary." - Q45tech
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Qproject wrote:what exactly is "TOE" ? I understand that "camber" is the angle at which the wheels-tires fall in or out.
A whole lot of information on the www.
http://www.tirerack.com/tires/...hid=4
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
antbo wrote: i saw the toe all contarted looking. ???
Contarted (adj.)
What one is when arriving at a club with Paris and Britney (or any acceptable substitutes) as your escorting tarts.
Modified by maxnix at 9:40 AM 12/13/2006
Q45tech
Remember my Q has been lower for 7 years, I finally found someone to buy [trade] my Eibachs and pay [supply labor] to replace them with oem and throw in 2 new rear shocks and a newish AC compressor [installed] in the process.............yes my 2nd [225k] bit the dust last summer at 305k.......80k on a remanned Calsonics not as good as a new one but 5 years is good enough.
Who is smarter in this case.
Falkdesigns
What does this have to do with an alignment???
Q45tech
Finally going back to oem springs and ride levels because even with a newish rear subframe [85k] the rear toe and camber adjustments are maxed out.................the on subframe mounting tabs eventually bend and not economical to change the subframe again............at least the 3/4" rise will fix the camber by 0.62 degree and the toe just enough.
The compressor had to do with reminding folks that even replacements need replacing again and again and again.
