evildky »
https://forums.nicoclub.com/evildky-u13100.html
Fri Jul 30, 2010 9:06 am
I recomend against doign a swap, for the cost of the parts needed and the labor invovled, save youself time and money and get a TT, they keep getting cheaper and the parts do not! if you must do a swap get a front cut, not only does this help ensure you get allt he aprts needed that wouldn't be included wiht a pallet motor, the body also serves to protect the engine during shipping so you are less likely to have broken accessories sensors oil pan etc,, also when you buy a front cut you get the odometer so you knwo how many miles is on the engine you got, if you buy a pallet motor you are buying a miles unknonw engine and anyone who tells you it's low miles is stupid or lying, search and see how many of us got bad pallet motors
keep in mind when you guy the pallet motor you still need;
intercoolers
hard pipes
oil cooler
as well as anything taht came broken or missing
and the trannies are the same, there are some design differences to allow for the larger flywheel otherwise the same, you need a shim to move the starter out otherwise the n/a trans is a direct fit
