Project240 »
https://forums.nicoclub.com/project240-u5974.html
Sat Feb 26, 2005 1:08 pm
Alright. My car starts up immediately now that I hooked up the ignition wire to the ECU. When I start the car, it idles at about 2000RPM, and it gradually goes up higher and higher. Eventually it gets to like 2600RPM and then drops to 1500, then revs back up to ~2600, then drops again, etc etc, like every 2 seconds.
It's not my AAC. I can hear the vacuum leak; it sounds the strongest near the back of the intake manifold. I can even hear it when I'm sitting in the car. There's just so much s*** back there, so many hoses and seals, and so much stuff in the way, and I can't tell where the leak is. I sprayed water all over the hoses to see if anything bubbled, but I didn't see anything.
Any ideas? What's the best thing I can do to try and fix this? Just start taking the entire intake manifold assembly apart and looking for cracks and holes?
Help
