AlabamaDan »
https://forums.nicoclub.com/alabamadan-u438.html
Mon Jan 29, 2007 6:00 am
Every Fill Up Check Tire Pressue Check Oil, ATF, PS, Coolant Levels Wash Car Every Other Fill Up Check Battery Add IsoHeat to gas tank Winter only, maybe every other tank. Every 3000 Miles Change Oil Synthetic or Synthetic Blend Change Oil Filter Mobil 1 BG44K Use with Full Tank on a long trip Clean Trottle Body Clean Mass Air Filter Inspect Belts and Hoses Rotate Tires Cross Rears, Front to Back Inspect Air Filter Check Window Washer Fluid Levels Inspect Brake pads, discs, drums, linings, lines, cables Inspect Steering and Suspension System Inspect Drive Shaft Boots and Shaft Lubricate Properler Shaft Grease Inspect Exhaust System Inspect Wiper Blades Lubricate Locks, Door Hinges and Latches Inspect the Underbody Every 15,000 Miles Brake Pads OEMs Replace Fuel Filter Every 30,000 Miles Replace Air Filter OEM Replace Tires Michelian Pilots Replace Rotors gniknave said "Every 3 resurfacing (20-30k)" Replace Belts gniknave said "30k" Replace Thermostat Inspect EVAP Vapor Lines Replace Radiator Cap Flush Transmission, Drop Pan, and Change Filter Replace Rear Differential Gear Oil Use API GL-5 Redline,Mobil 1, and even Amsoil are all excellent full synthetic gear oils to use. Every 60,000 Miles Change Spark Plugs Platimum Tipped Replace the Idler Pully gniknave said 60k Replace O2 Sensors Replace Motor Mounts Replace Shocks (60k on stock springs, 30k on eibachs) Every 100,000 Miles Replace Hoses Plemun Hose Replacement Replace Thermostat Replace Knock Sensors Replace Wheel Bearings Replace U-Joints (Driveshaft) Replace Transmission Mounts Valve Cover Gaskets Fuel Rail Flush Replace Chain Guides (90-93) Annually Flush Transmission Replace Brake Fluid Synthetic DOT-4 Use BG OIL CONDITIONER Flush and Replace Engine Coolant BG COOLANT ADDITIve Replace Water Pump Replace Wiper Blades Replace PS Fluid Use Mobil 1 ATF, BG P/S ADDITIVE Bi-Annually (Every 2 years) Replace Gas Cap Every 3 Years Replace Battery Use Pads to Prevent Coorosion Recommended Modifications Add Transmission Cooler Replace OEM Radiator with larger one
