DAEDALUS »
https://forums.nicoclub.com/daedalus-u128.html
Thu Nov 07, 2002 10:17 pm
Don't pin your hopes of unleashing 30 HP on this one task. Q ownership is a relationship that, like most, requires consistent work and attention in many areas. 10-years of unhappy marriage can't be made right with one boquet of roses.Set aside 3-4 hours and use any leftover time to become more familiar with the components under the hood and where they're referenced in the manual. If you're going to remove the TB you will need to get a new paper gasket for it. You'll be disconnecting the air intake hose anyway so clean that too. Check to see how dirty the inside of the plenum is; you may eventually decide to pull it to clean it and the runners, but then we're talking MAJOR work--not a spur-of-the-moment decision. There are a few sibling jobs that go along with plenum removal. While you're in the neighborhood get to know the EGR valve and the IAC behind the plenum. I'd suggest cleaning these too, but that's more work than just the TB. IAC uses a paper gasket as well. I know people have their intakes cleaned with pressurized solvents in a can. I've always wondered how effective these are. I would love to someday have an honest and fair evaluation done in which a dirty intake is cleaned repeatedly and inspected before and after each treatment. My first guess is that 50% of the mist gets combusted without even touching anything. My second guess is that even after a few treatments, most of the carbon buildup would still be there on the inner surface of the plenum. To be fair, I've heard that it does make a difference.
