Murdered_T »
https://forums.nicoclub.com/murdered-t-u92193.html
Fri Sep 17, 2010 4:07 pm
OK, car, 1979 280zx non-turbo, point-breaker ignition system. Car had a leak, was over heating, put fix leak in it, (I know retarded, but I was outta state on roadtrip an was low on funds.) Car ran fine till it overheated again later that day, filled radiator more, car wouldn't start. Roll popped it, started. So the car will only start if I push-roll-pop it. Got it home, no spark to plugs. Checked coil to distributor spark, non there. Replaced coil thinking that was a problem, no fixin it there, still no power from coil, so I am sure coil is not getting power. Don't have an oHm meter at the moment to test power wire to coil. Any suggestions would be much appreciated. Thanks guys.
