NateDogg »
https://forums.nicoclub.com/natedogg-u710.html
Fri Dec 31, 2004 11:26 am
the rattle is probably the timing chain. could also be detonation if the car is too hot and too low octane is used. or it could be rod knock. there is lots of info if you search about it in this and the 240sx forums. your overheating is probably caused by air in the coolant system. do a search for "coolant bleeding" or something similar and you should be able to properly bleed the air out of the coolant.
