240sxbobbis wrote:i know your supposed to tune your car to run with those mafs if you could either get a safc you can probably tune it to run with it . if not then just visit the junkyard and pick up an sohc maf from a ka24 e
did you even read the ? i asked.it is tuned to run the set up i have.by the safc 2 that i said i have.and 240sxbobbies thanks for the info but if have a ? that you needs to be ask please dont highjack this post.
240sxbobbis wrote:i got one of those and my motor runs great . quick question what fan do you have on your ca motor im trying to use my ac fan but i cant get it to kick on you have any suggestions ??
i got a 16 inch fan from the auto parts store.
89’ClubK’s wrote:He mentioned using a Z32 MAF w/ SAFC II. But if the ECU is bad or there is a bad wiring connection, the SAFC won't do anything.
already checked the wiring for the car.
