garagelu wrote:you dont need to buy a restrictor if you buy the new 2871r. They come already installed. There really is only two places to get turbo lines. One is taka which are about 160 dollars. The other is circuit sports which are around 120-130. Taka uses Earl's fittings and Circuit sports uses russell fitting. Both are good, but earl's fitting are a little better quality from what I have seen.
The other option is to custom make the lines by buying the pieces seperatly and put it together yourself. You are still going to spend about 90-100 dollars doing it yourself so I would just save the time and hassle and buy the kit.
Orrrrrr....... you make your own, its really easy.
Also I am selling this, I'll be posting it in a big fs thread soon but would rather help the regulars in this section first.
S15 turbo, tubular manifold, turbo elbow, oil and coolant return line
Also, avc-r, z32maf, z32 maf filter and enthlapy ecu tuned for 740cc dwerks injectors.
