AZhitman »
https://forums.nicoclub.com/azhitman-u113.html
Sun Mar 26, 2006 4:30 pm
As you all know, I got tired of fiddling around with a half-a$$ed setup. I am in the midst of a full-on build, with pistons, rods, 50-lb injectors, T3/T4, Walbro, AFPR, HV oil pump, crank scraper, windage tray, block work, head work, and lots of other high-end goodies.
Basically, the engine is being built for 400rwhp, but I intend to remain between 8-10 psi.
I'm going for ULTIMATE reliability and durability, as well as LOW maintenance.
WIth that being said, I need some advice on engine management. I have heard everything from JWT, Biki, E-manage, SAFC-II, etc etc etc...
I don't want to spend a fortune, so if it's upwards of $600, I'll probably pass. I'd love the idea of eliminating the MAF sensor. Simple = GOOD. I want to DRIVE the car, not tinker with it...
Thanks in advance, if someone can ediucate this n00b on the ways of engine management.
