rbsileighty »
https://forums.nicoclub.com/rbsileighty-u4927.html
Wed May 03, 2006 7:21 am
My FMIC is pretty small as you can tell by the pic in my sig... I'm hitting boost cut
Where is your pickup for your boost now? Take it at the turbo (tap into your wastegate actuator) and you'll see what kind of boost drop you do have...
Sounds like you are exceeding the compressor's eff range the way the boost is running... but that wouldn't make a lot of since at that boost level unless your turbo is actually boosting much higher than your current boost reading...
