I would run baffles to minimize the complication factor. Since you will be driving around corners, in an extreme condition the extra pick-up could begin to intake air which would frothe the oil that is coming up the tube, and it also would lower oil pick-up due to air being easily evacuated compared to the much heavier oil.WDRacing wrote:Very interesting idea Alan...I never really contemplated that before. It would be pretty easy to cut an weld on some side extensions and insert a baffle on the inside. The you could have the return line tap into the top of the extension, which would be ideal for a gravity return system. You could also improve the oil pump pickup at the same time. Using a muti-port suction tube. So you could have two pickups allowing you to draw oil from both side of the engine. Or maybe just baffles....lol.
WD
There has to be a KA24E pan out there with the GT3 cars running those engines, but I'm sure those will be way out of your price range.Structure240sx wrote:i have thought about this for a while. i have meant to get an extra pan and have my uncles machine shop make me something. i just keep letting the idea slip away. its a shame greddy doesnt make a pan for us like for the sr guys.
there was talk maybe a year ago or so on ka-t.org that rick was working with a company to make an oil pan and a few other things. i guess it never happened
Not really... there are some weird angles in an oil pan.4felix20 wrote:god that would be so easy to weld up....
Just cut the pan when you get it.WDRacing wrote:If you strip it and etch the surface do you still need expensive paint??
Does anyone have a spare oil pan I can have or buy for a decent price to start working on this. I have a bunch of mild steel sheet just waiting to get played with. Also, anyone have any idea of exactly how thick the pan is, I'm to lazy to crawl underneath with a dial caliper.
WD
Just cadmium plate it.s13sr20chris wrote:yeah, and you have to strip the paint and try to paint it back up afterwards. i tried that and its a huge pain. the pain for oil systems(glyptal) is expensive too.
good call. a buddy of mine is helping me fab up a pan for my sr. we are going by the pics of the tomei and greddy pans. i wanted stainless for the above reason and durability. he wants thick sheet aluminum as he says it will dent instead of shattering like a cast pan.Nismo_Freak wrote:
Thats what Tomei did to theirs from the look of it.
Thick aluminum runs more of a risk of cracking than sheet thin steel.s13sr20chris wrote:good call. a buddy of mine is helping me fab up a pan for my sr. we are going by the pics of the tomei and greddy pans. i wanted stainless for the above reason and durability. he wants thick sheet aluminum as he says it will dent instead of shattering like a cast pan.
Deal, if it doesn't work out to well it's your motor that dies from oil starvation...lol.AZhitman wrote:I got a spare pan we can mess with Brian.
My only caveat - It goes on MY car when we're done.
yeah, i know. hes into the aluminum thing. i will be content knowing it is better than cast aluminum(greddy and ebay) pans.Nismo_Freak wrote:
