As I'm finishing up my Bluebird SR swap, I've hit a few delays. One being my topic for this thread. I'm part way through installing my oil pressure gauge and the threaded piece that goes with the oil filter adapter plate will not allow the long shaft to pass through it. it fits the oil filter fine. It is threaded for a short distance then gets narrow inside. The shaft on the other hand has over an inch of just shaft before it's threaded. Doesn't seem to make sense why that shaft is so long. (I've thought about cutting it but that would be a last resort) Has anybody tried this Prosport gauge before... if so, do you have a specific part that worked for you? I think the fitment is the same between my bluebird and the sr20de.
Here's a link to the part I got....
http://prosportgauges.com/oil-....aspx
I appreciate any info you guys have. You've come through for me before, I trust you'll do it again.
