Oil Weight
Discussion of Infiniti's amazing (and underrated) sport-luxury crossovers, the EX35 and EX37. For 2014, the EX series will be renamed QX50, in line with Ininfiit's new naming conventions.
jamesstock
Car: 2010 Liquid Platinum/Stone Journey
Diamond Cut IR Tint
Does anyone know if it's ok to put in 0w-20 full synthetic engine oil on the EX35? Location: California, hence barely touch any snow unless I hit NV which is at most 3days in a year (if it happens).
James
CDNicecube
Car: 2010 EX35 Journey+Tech+Navi
Hi
Let me preamble this by saying I am no expert in Oil and Lub.
My question is what benefit(s) are you hoping to obtain by going to a 0w20? Not mileage as that only appears when you have 1000s of cars. Do you have an engine problem you want to address (noise?). My thinking is if all is fine with your EX, why second guess the highly trained engineers who developed and improved the VQ engine over the last 10 years, and know the engine inside out? :)
My second reaction is the the 0 weight (in 0w20) is actually better for cold weather, which your car will not see. So I think that one or twice using a lighter oil you might be fine, but I would not do so over the life of the vehicle, personally. There is also this warranty thingy that could be impacted if something goes wrong and they discover you have been using the wrong weight oil.
There is some debate on Bob Is the Oil Guy as to whether synthetic oils are better than good quality dino oil for normal OCI (which is 6.5km for us Canucks). I know our Infiniti dealership uses Mobil 1 in the EX and other Ester oils in some Nissans (albeit there is no mention of us having to use Ester oil or even synthetic oil anywhere in the EX owner manual). I use Mobil 1 5w30 because I trust it but could explore other synthetic if I had the opportunity and I find some on sales. I use synthetics because of our weather which can get very cold for long period of time.
Sorry I cannot be more of help. I would not do it.
canuck99
jamesstock wrote:Does anyone know if it's ok to put in 0w-20 full synthetic engine oil on the EX35? Location: California, hence barely touch any snow unless I hit NV which is at most 3days in a year (if it happens).
James
If you had no other choice, it's better than going with no oil. Why would you want a lighter viscosity oil?
EXceptional
Car: 2008 Aspen Pearl EX35 Freakin Loaded!
I wouldn't do it either.
Stick with the Owners Manual until your Warranty ends... then, you can put anything in it.
I still wouldn't do it, in your climate... even after the Warranty ended.
Return to “Infiniti EX35 / EX37 and QX50 / QX55 Forum”
