Ill check it out tommorow and post again. I actually got the whole car for $1000 not jus tthe engine (last owner hit something and bent the lower subframe, everything else appearced to be fine), I just pulled the engine (and later the water pump) because thats what i needed to get rolling again on the original car.masticatingcow wrote:Where is the rattling coming from? Have someone start her up and stand RIGHT OVER the engine bay and check it out. Pay very close attention to it because frankly, rattling could be LOTS of things. Post up when you have a SPECIFIC location of the rattle, and we can help you a lot more.
The dimmed oil light sounds like an electrical problem, not an oil problem.
The erratic behavior of the temp needle is VERY WEIRD. When you isolate the rattling, maybe we can help for with that. I am inclined to think that that is also an electrical problem, however.
I would NOT run a diesel mix through your engine just yet. No matter what you were told when you got raped for $1000, it's not brand new. I promise you that. However, I think the rattling, which seems to be the biggest problem, is probably an easy fix. I won't go whole hog on that until you get some more specific detail, but we'll see.
Not long ... I wouldn't imagine you could get more than 10 - 20 miles before it goes completely.my240isapiece wrote:shop called today said the engine was "gone" so im gonna guess its a thrown rod like nismo said. How long can I drive on it before it goes completely?
- Raleigh
damn!!! that sucks. AND u have a full tank of gas! that would piss me offmy240isapiece wrote:I appears that the first cylinder actually went badi unplugged all the fuel pump wires one at a time and listened for knocking, pulling the wire from the front cylinder seems to make it knock less. I just filled up the friggin gas tank before i took it to the shop so im driving it whether it likes it or not!
- Raleigh
God, you have a point. -----------DAEDALUS wrote:Cost of full tank of gas: $30Cost of bad engine dying on freeway or in the middle of an intersection: Priceless
why in the hell did you do that? the knocking is from the lack of oil lubricating all the moving parts in the engine. ill guarntee you spun a bearing. the engine now needs a rebuild. that is a very costly lesson you learned. never EVER EVER EVER DRIVE A CAR WITH THE OIL LIGHT ON.my240isapiece wrote:Crap crap crap! Soooo I put in regular gas today because high test was a rip where I went, and it made the knocking much louder and knocks are idle RPM. Acceleration crapped out significantly too. I also opened up the hood right after parking the car and there was smoke coming from underneath the engine. It wasnt a lot of smoke but I assume any smoke is bad, it looked to be coming from underneath the heat shield over the headers. Smoke was not blue or oddly colored and I think it might be just an exhaust leak (I hope).
Knocking noise is coming from... the engine, sorry that doesnt help at all but it is hard to isolate the noise as it is a fairly loud knock. Sound seems to be near the top of engine. If the problem is oil pressure do i just need an oil pump? Is this an expensive fix ?
I am not a car expert but I'm thinking nizmo is on the right track, because it the timing chain tensioner is oil pressure assisted and i have low pressure, that offers the explanation that the timing is off due to incorrect timing chain tensioning and thus causing the knocking... or am i mis-understanding something?
Thanks for the help btw guys.
- Raleigh
