Oil used???
chaosli
Car: 89 nissan 240sx coupe FTW
99 mazda miata
93 bmw 325i RIP
soo i am doing a ka et and i was going to get some motor oil for it but i am just wondering if i should go for the watery grade like 5w-20 or go for the regular stuff 5w-30 or 10w-30
WDRacing
Anything will work well, but try to stay at or above 5W-30 and try to use synthetic if you can. I'm currently using 5W-30 Super Tech from Wal-Mart. It's cheap but good, unless you're buying Royal Purple or Redline I think most Synthetics are pretty much the same.
I used to use 20W-50...but I have since decided that it doesn't flow well enough. Especially when draining from the turbo. Just my opinion though.
WD
lrb_2000
Car: '91 Nissan KA-T hatch
I also use the 5w-30 supertech oil .. haha.. i've been using it for quite awhile.
abc123omg
Car: '93 240sx KA-T
when ihad my kat, i used 10w40. either conventional or synthetic is fine, as long as you change it out regularly at good intervals.
