Oil types
All things Altima Coupe.
alphapig
Car: Nissan Altima Coupe S 2.5
Alright so I just did an oil change at 8.5K miles, and decided to switch to fully synthetic. Got a K&N oil filter and some Valvoline 5w20 synthetic stuff.
So what are all of you guys running? Or is it too early to ask as not many have changed their own oil yet?
uh-oh_8_coupe
Car: 2008 A/C Dark Slate 2.5
i plan to go full synthetic, leaning towards mobil one..... but not till after my 2 free oil changes
galanw
Car: Altima Coupe
i thought the manual says the AC uses 5W-30 instead of 5W-20?
loxm86
Car: 08' Alt/Cpe 3.5SE 6MT
MOBIL One 5w30 with a K&N Filter!!
smmehdiz
Car: Altima Coupe 3.5 SE 6spd
on my first oil change i did castrol synthetic blend w/ mobil 1 filter but now i do mobil 1 full syn and filter
squik
Car: Altima Coupe 3.5se
Royal Purple 5w30 with what ever Oil filter Nissan puts in at the dealership. I was thinking of doing it myself now that the weather is nice, but I would get one of those "High flow replacable filter" type of oil filters just to see what they are all about. I think they are just slightly more expensive then a throw away filter to buy both parts, then the filter element itself is cheaper, I am not sure though.
NissNEZ08
Car: 2008 Nissan Altima Coupe 3.5SE (Premium Pkg, Tech Pkg, VDC, CVT & Blk Leather)
Well you say you want to run full synthetic so that rules out Mobil 1, Valvoline, Royal Purple yada yada regardless of what the bottle says. If you want a full synthetic motor oil you will need to buy Redline or Amsoil. If you have the receipt for the valvoline take it back and get your money back. K&N makes good oil filters, so your o.k. there. If you want to buy a damn good "synthetic" oil that has much better used oil analysis results than the previously mentioned oils buy yourself Penzoil Platinum. I run that in the A C and my Z06.
Oh, and don't be afraid to switch to a synthetic motor oil on your first oil change! The old "Don't break in a motor with synthetic" is pure non-sense. I wouldn't put royal purple motor oil in my lawn mower. It's garbage.
Mark
D-Roll
Car: 08 Nissan 350Z Touring Coupe
Running Mobil1 5w-30 full synthetic right now...might run Amsoil 5w-30 full syntheic next time oil change, goodstuff.
Dexion
NissNEZ08 wrote:Well you say you want to run full synthetic so that rules out Mobil 1, Valvoline, Royal Purple yada yada regardless of what the bottle says. If you want a full synthetic motor oil you will need to buy Redline or Amsoil. If you have the receipt for the valvoline take it back and get your money back. K&N makes good oil filters, so your o.k. there. If you want to buy a damn good "synthetic" oil that has much better used oil analysis results than the previously mentioned oils buy yourself Penzoil Platinum. I run that in the A C and my Z06.
Mark
Almost... Mobil 1, Extended Performance is actually a full synthetic. The other mobil 1 is not. I use the $6.99 a quart extended performance type. Its good for 15,000 miles.
adidas2go
Car: Cycle through all kinds of cars, trucks, motorcycles, and boats 🤙
Once upon a time: 1st turbo Altima Coupe
Mark
Whoa whoa whoa. Yeah, first off, Mobil 1 makes the best traditional motor oil in the world, Period. Its been proven, its been road tested, the results are all over the place. As for the non traditional oils like AMSOIL and Redline. They are good stuff. AMSOIL is far better in motor oils than Redline and Redline is far better in transmission oils than AMSOIL. I have ripped apart a dozen blocks through the years and I tell you what, I have never seen more sludge build up in any engine more than I did with Penzoil. That sh*t is absolutely horrible. Bad stuff to use in your engine, period. Same goes for Quakerstate, now that they are merged. Don't trust it. Mobil 1 fully synthetic FTW for traditional motor oil. AMSOIL is the best oil by far though. Far less breakdown than any other oil at comparative levels.
galanw wrote:i thought the manual says the AC uses 5W-30 instead of 5W-20?
The latter number is how thin the oil gets and its shear point. Basically 5w20 oil has less film and shear strength than a 5w30, 10w30 or a 0w30 motor oil. This can lead to increased engine wear under today's demanding heat and high-stress engine performance conditions. I would stick with the manufactures recommendation on this. The first number is how cold it can be outside and still pump the oil through during start up. Honestly, in Cali you could run 20W-30 all day. However in conditions like canada you would need 5W-30 because the temps are much colder during start up
LongBeachCoupe
Car: 08 Altima Coupe (RIP Hurricane Sandy)
2005 Lexus RX
Im on the same stuff, but i feel funny not changing it lol. 5k gets me goin lol
LinkNuc
Car: 2008 Altima Coupe 3.5 SE Super Black 6MT, Loaded minus Moon Roof Deflector
Whatever 5W-30 Synth is on special at the time oil is oil.
