szh »
https://forums.nicoclub.com/szh-u149.html
Mon Jul 14, 2008 3:47 am
When measured consistently (level ground, cold engine - sitting overnight, etc.), the difference between the H and L marks is about 1 quart, as I recall from earlier discussions.
Using 1 qt or less in 3750 miles (my OCI) is pretty normal for this engine - higher for some folks and lower for others. If you use 1 qt per 1000 miles or less, then Infiniti will swap out the engine (still needs arguing though).
I add about 1/4 to 1/3 qt at the half-way mark between oil changes - at about 1700 miles or so - just to keep it above the midpoint between L and H.
Z
