oil thermostat for oil cooler
bentvalves
Car: 89 Silvia K's
http://www.pegasusautoracing.c...=1226
how come there are 4 ports on this thermostat?
one side for feed to the cooler, the other for return to block???
Greg
mbmbmb23
ks13 wrote:http://www.pegasusautoracing.c...=1226
Greg
When the temp is low it comes in one side, cuts across the middle of the "H" and back to the block. When the thermostat opens it comes in the same side, skips the middle, and exits to the cooler, then comes back into the unit and exits from the same port as with the thermostat closed. The female threads on the sides are probably for mounting purposes.
-m
ca20det
Car: 89 240sx 93 sentra
is it that much needed?? I mean is 180F a good temp for the CA under normal operating temperature is going to need this... I think the CA runs kind of hot already.... maybe some input from Dee or else...?
bentvalves
Car: 89 Silvia K's
Deff needed, especially when just lightly cruising, your oil will take forever to get up to operating temps.....cold oil = no good.
Not to mention if you live in cooler climates etc.
float_6969
Yea, must have for cooler climates...
