Darius wrote:Ok that sounds exactly like what I'm seeing. I'm running 5w-30 Mobil 1. I am somewhat surprised to see that your oil-air cooler keeps the oil at the same temp as the stock oil-water cooler setup. I figured it would be lower than mine. Do you have a fan on the oil cooler?
no fan or ducting on the oil cooler. adding some ducting is in the works and that should help a lot. the oil cooler makes a big difference, but mainly on the track and while moving. stop and go it doesn't do too much.
i am in the process of bypassing the factory oil2water cooler now as well. when i had just the oem cooler on, the temps got hot much faster and would stay hot (210-240). wiht the external cooler my temps climb slowly from 180-210, and drop back down to 180 if i'm doing a lot of highway cruising. it will eventually get hot with serious track driving though, but the car lasts MUCH longer out on the course with the external cooler.
