lrb_2000 »
https://forums.nicoclub.com/lrb-2000-u28436.html
Thu Apr 20, 2006 4:18 am
Hey,
I installed a few gauges (water temp, oil pressure, oil temp)...
I used a + fitting off the oil pressure switch for the oil pressure, oil temp and oil feed.. now, the oil pressure reads fine.. but the oil temp gauge never moves... so, I plugged the sender wire into the water temp gauge, which starts at 100*F instead of 140*F like the oil temp, and it never read above 125*F.. which I know can't be right for the oil to be that cool.. so, my question is.. is that a bad location for the oil temp? Should I move the sender to the oil pan? and if so, is there some sort of adapter for the oil drain plug, so I don't have to tap the oil pan?
here's a pic of what I used..
