oil temp gauge
quiksilvia
Car: 95 s14 se
where should the sensor go? its a long probe with a threaded nut on it
Dori Dori
Car: Cars of course
You can tap into the drain plug (or get a pre-tapped plug).
VitaminT
Car: 93 240sx SE
The Greddy Oil filter relocation kit had a place for temp and pressure sensors. That is always an option, and you get the bonus of not covering your alternator in oil every change.
Dori Dori
Car: Cars of course
I have one and project silvia is the only place that I know of who has them in stock. :D
GTS4-R
Car: my feet
I fu have a GReddy oil pan than it'll have a spot for it to thread in right next to the drain plug ;)
VitaminT
Car: 93 240sx SE
Oooo, forgot about that. I have one of those too.
BaliLover
Yup, the Greddy oil pan and relocation kit give you TONS of places to mount sensors. I think the pan has 1 place, and the relocation has 4.
s13sr20chris
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
I'm assuming the relocation kit would be a suitible place to mount a oil pressure sensor?
VitaminT
Car: 93 240sx SE
You can mount it in the adapter plate that screws into the block where the oil filter used to go. That is VERY near to the stock sensor so I think it should be fine.
I don't know if I would mount it in the remote block, but really haven't tried either (yet).
BaliLover
Mine is on the remote block and seems to do fine, always reads good numbers
Onizuka
cool, thanks for the info, time to go order relocation kit... :cool:
240SXer
Car: 1995 240sx SE (2jz powered)
Does anyone have pix of a relocation kit mounted on S13 or S14?
Hijacker
Car: '92 240sx Convertible
'94 F-150
240SXer
Okay.. thanks.. that works.. I think i'll just get one of those. It makes things easier. Not much extra money (i'd have to get that $50 nissport adapter anyway). What about if I want to add an oil cooler later though?
GTS4-R
Car: my feet
the greddy oil cooler runs off the oil sandwich adapter (which also has hook ups for sensors)
240SXer
Ya, at that point it would suck, how important is a oil cooler for drag racing?
VitaminT
Car: 93 240sx SE
I am really not that sure, but I would think that it is less needed in drag than other motorsports (i.e. roadrace when you are reving you motor for 30 min. straight.)
I would just get a gauge and watch the temps. With you only running the motor hard for <15 sec per pass I wouldn't think one is really needed.
240SXer
I do some top end pulls too though.. Like 40-140 and stuff like that. Not too often though, mainly drag. Is there any way I can buy a cheaper oil cooler? Or make one?
VitaminT
Car: 93 240sx SE
Yeah, but I wouldn't worry too much about it. I mean even top end pulls aren't that long. I guess that is my opinion anyway. I mean it is not like you are going to be bouncing off the revlimiter for 1 hour + like some guys.
You can buy an oilcooler core from several places (I think B&M makes a decent one). Then you will have to fab up some lines. Personally I just got the Greddy oilpan. I holds an extra quart and also has fins to cool some. Aluminum too.
240SXer
Ya, I think i'll just get the pan. Does anyone have a pic of it installed? I want to see if it hangs down at all or anything. I'm gonna get the oil filter relocations, then later get the oil pan.
VitaminT
Car: 93 240sx SE
http://www.thedaemonofid.com/t...r.JPG
Sorry it's pretty big. Remember that the view of how low it is can be influenced by the angle of the camera.
240SXer
Got any more pictures? Is it the lowest point in the front of the car? I'm worried about it hitting. I'm on stock suspension but i've rubbed my downpipe before..
VitaminT
Car: 93 240sx SE
Try this.
http://www.thedaemonofid.com/t...on%20(Small).JPG
If I remember right the pan does not hang down ANY lower than stock. It just has the extra capacity on the sides. Let me know if you want to see more pics, I have them, just not any on the car.
