OIl temp gauge install
driftneil
Car: A pile of cars.
Whats up Nico......Was trying to install a oil temp gauge today and ran into a little wiring issue. I had installed a sandwich plate in between the filter and the block, this is where i placed the temp sender. Welp I ran the wire for the sender thru the firewall, and to the designated wire on the gauge. then put the ground to ground and the hot, to the remote of my stereo. When i touch the hot to the remote wire the gauge pegs all the way up.......Cant figure this out so anyone that has this install under there belt let me know. Btw it's a 95 240 and an AC,S7 gauge.One thing I was thinkig was the instructions say the threads of the sender goes to ground, should I not have teflon taped this? thanks again.
driftneil
anyone
redtop91
Car: ↑ ↑ ↓ ↓ ← → ← → B A Start
Is it a mechanical or electrical type gauge.
driftneil
Sheesh my fault....electronic
redtop91
Is it a 12V gauge?
driftneil
yes sa
redtop91
Where did you ground it?
driftneil
to the antenna wire.
redtop91
Hmmmm I dunno about that as a ground point but I can't speak from experience. Damn you've got an interesting one there. My vote would be that it isn't grounded properly but I doubt that is the problem.
driftneil
Eh I know if you dont have the ground to the radio hooked up, yer stereo will still work. figured it....was but who knows? Imma try tommorrow prob, Ill Let cha know if it works. Or if anyone has any feedback on anything including the antenna as a ground.
slipnfall
Car: '06 D40
Ideally you should run a seperate ground from the oil sandwich adaptor (or nearby) inside to supply the ground for the gauge.
Without a sensor/sending unit hooked up, the gauge will default to pegging(full temp/psi/whatever): so you either have a bad ground and/or signal connection, or bad sensor.
You can test the gauge by grounding the signal wire, it should return the needle to zero.
You can test your sending unit + wiring by taking an ohm reading between your gauge ground and the signal wire: you should see at least 1kohm or so(depends on the sensor, manufacture, etc). A short or open is no good.
Teflon tape should have been OK, unless you used a ton of it. They advise against it for a reason.
driftneil
Sweet imma get to that prob sunday er monday, thanks alot man. Keep you posted.And as for the teflon tape, figured it would be good. The instructions are so s****y just 6 pics of useless crap.
