Doogz wrote:-Isn't it bad to run oils that are so far spread apart in their viscocities? -Like 5w40s for example, don't they have to add a bunch of extra crap or something to make the oil perform like that? -I always heard it would be better to run an oil with less of a range.
Everything you heard is correct, but nowadays with so many oils out tehre whose innate viscosity index is high and less VII's are used its not quite that simple anymore:
if all other things are equal, the answer is yes, its generally "bad".
Back in the day, almost every oil was a group I base oil, with little innate ability to display a multiviscosity spread ( this is called viscosity index)This was improved upon with polymeric thickeners which brought multiviscosity oils into widespread use in the late 40's early 50's.
For example, to achieve a 5w-30, you took a 5 weight oil and added polymeric thickeners ( so called viscosity index improvers, VII's), which uncoil under raising temp and grab other molecules exerting a thickening effect.
Multiviscosaity oils were a big advance.
The disadavantege was, that these VII's break down themselves, thinning out the oil in the process and turning into varnish in your engine after a while ( in turbo engiens quicker than in others).
Also these extra VII's have to find "room" in your oil formulation and will therefore reduce the %age of other important additives in your oil.
Within the same quality base stock used: The less range the less VII's used, which mean a more stable and cleaner running oil.
It then follows, when using multivis, to use a smaller spread like 10w-30, 15-w40 or 20w-50, rather than say 5w-30 ( a horrible grade in a dino oils it makes no sense why manufacturers are recommednignit as a year around oil, I guess they dont trust folks to change by the seasons)
Nowadays some of the better Dino oils use group II base stock or even group II+ ( like Chevrons "isosyn" or Pennzoils "purebase"), those have much better innate multivis behaviour and so need less VII's to achieve multi vis.
Synthetic oils which run from group III oils (hydroisomerized, examples Syntec, Kendall Syn, Valvoline SynPower) to group IV (PAO 's more expensive a bit better, example Mobil1 + AMSOIL) to group V (most stable Redline, MOTUL).
All synthetic oils are safe to run in bigger spreads, whether its 5w-40 Valvoline SYnPower or 5w-40 Kendall Synthetich both good oils.
With a group IV oil Mobil1 can make a 0w-40 which is equally stable as the 5w-40 SynPower which is a group III.
Redline now has a 10w-40 that is VII's free which is amazing for such a wide spread and wouldnt be possible VII-less, w/o using a polyolester base group.
Other factors though apply too.There are VII's of different quality, while its easy for us to find out the base lubestock of a given oil (from the MSDS) its harder to find out about those.
So not every group IV is automatically superior to every group III.And not every group III is automatically superior to every group II+.
the rest of the additive package has a significant effect too, so the above isnt always a clear cut guide to whats "better".
Fred...
