Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Fri Jul 27, 2007 1:44 pm
Your options for the pump are to stick with stock.
The pickup doesn't break. What happens is that when you get your motor, depending on how the motor was shipped, the stamped steel pan could be dented. And when the pan gets dented, it ends up getting pushed against the pickup, and starves the pump.
The solution: Pull your oil pan off and beat out any dents you see.
