oil sending unit
mean green s14
Car: driving like a retard
hi i have a 97 240sx and am installing a turbo kit and was wondering what size is the bolt on the oil sending unit? i need to find out what size it is so i can tap into a oil source.i need to tap into the block where the oil sending unit gets unscrewed and need to hook up a loine there. what size is it i tryed 1/8th but it doesnt thread.
NISTECH
27mm
mean green s14
would a 1/8bspt work?
NISTECH
the sending unit itself is actually a special socket pattern but a 27mm 6point deep socket works well on it. I dont believe a 1 1/8 inch socket will work.
mean green s14
im talking about the actuall threaded part that goes into the enine blick not the head that you use to unscreww it
NISTECH
oh...sorry...It is a pipe thread [tapered] not sure on the size believe it is 8x1.0 most 8mm bolts have a 1.25 thread but I believe it is a tighten thread onit for sealing purposes. I seen a thread were our sentra master EZCheeze posted an adapter for that port that has a t off it to attach the sender and a line. search the technical forum for sentra it was a recent post. All the nisan senders are the same thread.
DAEDALUS
Car: 1990 Infiniti Q45
Took me a while to find the thread, but here it is:
http://www.nissaninfiniticlub....54020
I need one too but damn, $50?
