My bad. I'm glad you brought this up, I was totally spacing when I posted my commnent. my OIL FEED LINE has 1/8 NPT ends. D'oh.DRIFTEADOR wrote:actually most cars i've seen, nissan included, use british standard threading on oil senders (BSPT not NPT). you can use the npt fitting but it may not seal and even if it does, you won't be able to go back to stock because you'll ruin the threads on both the block and sensor. worst case scenario this may happen.
