groundhogday1976 »
https://forums.nicoclub.com/groundhogday1976-u4144.html
Sun Aug 17, 2003 3:07 pm
I'm still doing research for my distant KA24DET project. It'll probably be at least a year before I actually do it. Anyway, most everybody puts their turbo oil return line on the pan. In the turbo install at 240sx.org, they eliminated the distributor and put the return line it that space. I'm afraid of the oil backing up if it's routed to the upper timing cover, but it got me thinking. Couldn't I drill and tap the lower timing cover when I do the timing chain (which I need to do soon) and plug it w/ a short bolt, then when I install my turbo setup just connect the return line there? Any pros/ cons to this would be appreciated. Also, would putting an oil cooler in the return line cause problems w/ oil backing up?
