I go down to the local speed shop to get a knew oil bung fitting because I messed up the one I had by trying to over tighten it. I tell the sales person that I have been having problems with the oil leaking and wanted to know if I had the correct fittings and what they would recommend me to do to fix it. I end up showing the Shop`s mechanic the oil pan and the fitting I was trying to use. He tells me that the fitting I was using -6AN was to small and that I should be using a -10AN size. Anyway I was wondering what everybody else was using? I decided to buy the -10AN but now I have reweld the bung another 1/4 away from my air conditioner bracket
