brokeAs240sx wrote:
Do you know what sealent they use?
it's a generic silicone-based sealant. The brand they use is made by permatex although most silicone-based oil resistant sealants should work. Link <-that's pretty much what it is.
Keep in mind the oil bung they include in their kit isn't ATTACHED to the oil pan via the gasket maker, that stuff only seals it. they include two self-anchoring 'nuts' that you have to drill holes for that anchor it. I got the IAP kit and elected to drop my oil pan instead of using their anchors. It can be done like their instructions suggest but personally I didn't find it too difficult to remove the oil pan and decided to go that route instead.
I DID NOT REMOVE MY CROSSMEMBER TO GET MY OIL PAN OUT. I DID HAVE TO BE CAREFUL WHEN REMOVING AND PUTTING IT BACK IN NOT TO BEND THE MESH FILTER ON THE END OF THE PICKUP. (sorry for caps but I wanted to dispell the myth about having to remove the crossmemeber and it's very important not to block the oil pickup)
To remove my oil pan I attached a chain to the AC compressor bracket that bolts to the block, unbolted my driver's side motor mount, and with an engine lift, lifted the the motor. I did have to remove my front anti-sway bar as well. I think it took me about 20 minutes. Trust me you'll be thankfull of the ability to clean it while it's out anyhow. check my cardomain site for pics. I wanted a cleaner hole than I could have drilled from under the car anyhow. my dad has a drill press and i wanted to drill the oil bung using that for a cleaner connection. don't forget to use teflon tape around all of the fittings too!!
