daniel240 »
https://forums.nicoclub.com/daniel240-u4418.html
Wed Mar 31, 2004 6:20 pm
ok, first you really need to search. but i will help you out. you get the oil from your oil sending unit, located under your oil filter. there is a sensor that is screwed in there. you get a T fitting and screw it in there, with the sensor in one end and run an oil line from the other end to your turbo. and to drain the oil, you run a larger line from the bottom of the turbo, down to your oil pan, which you will have to drill and put some kind of fitting or elbow in. this needs to be towards the top of the oil pan. search and you will find more info on this with more details.
