ks13 wrote:I had a friend running a 2871 without a restrictor for 2 years strong, no smoke issues as well.
they are required to have one fitted however, just go on garrets website and have a look at the specs for GT series turbos.
the turbo will live a shorter life as a result of having more pressure pounded through it constantly. A garret gt series turbo only needs 20-30 psi to lubricate it effectivley, not 80+ psi at redline.
I 100% guarantee you that there is a restrictor in the Core from the factory. Like i said if you have a BB and have a look in the inlet you can see it.
Where on the GT spec's page do you see that the require an after market restrictor???
http://www.turbobygarrett.com/....html
MeanGreenS13 wrote:white smoke? thats not turbo related buddy... that sounds like maybe a head gasket issue... white smoke is water or coolant... does it have a sweet smell to it?
White smoke is oil smoke but condensation is water they look the same but of course the smoke lasts.
I have a feeling that this might be a case of Valve stem seals leaking not the turbo itself. If the smoke is more on idle and in vacuum conditions then that is the case.
--------------------------------------------------------------------------------------------------EDIT!! Here is the Actual Info about the Oil Restrictors From the Garrett Page.So to summarises what is below if you haven't modified your oils system and the oil pressure is within the factory specs (i.e. 51-60psi) then the standard Garrett restrictor is all that is required.
Garrett wrote:Oil & Water Plumbing
The intake and exhaust plumbing often receives the focus leaving the oil and water plumbing neglected.
Garrett ball bearing turbochargers require less oil than journal bearing turbos. Therefore an oil inlet restrictor is recommended if you have oil pressure over about 60 psi. The oil outlet should be plumbed to the oil pan above the oil level (for wet sump systems). Since the oil drain is gravity fed, it is important that the oil outlet points downward, and that the drain tube does not become horizontal or go “uphill” at any point.
Following a hot shutdown of a turbocharger, heat soak begins. This means that the heat in the head, exhaust manifold, and turbine housing finds it way to the turbo’s center housing, raising its temperature. These extreme temperatures in the center housing can result in oil coking.Ref':
http://www.turbobygarrett.com/...101_3
And here is the section out for the manual regarding the Oil system Spec's
Modified by D_Stirls at 5:18 PM 3/9/2009
Modified by D_Stirls at 5:20 PM 3/9/2009
