The interval is 90 days or 3,750 miles which ever occurs first.
Oil is tested at running hours [65 hours at cruise rpm ~~3900 miles at 60 mph] for evaporation an TAN changes.Real Synthetics usually pass these test at 100 even 120 hours of use.
Oil filters on the other hand are too small to handle 100 hours of use [6,000 miles at 60 mph].........with synthetics inportant to adhere to 90 day oil filter change and top up what is lost with more synthetics.
The oil sump is tiny in a SR20 compare to German brothers of equal size this limits the life of the oil.
http://www.swri.edu/4org/d08/G...t.htm
"attended a meeting with the EPA and various stakeholders in the automotive aftermarket on the roll-out of the new GF-4 motor oils. This is the next generation of motor oils to appear with the coveted (and auto manufacturer recommended) sunburst logo. The logo is the symbol of the API and SAE certification of motor oils. The EPA is touting the GF-4’s as environmentally friendly products due to a very low sulfur content (sulfur will contaminate newer sensors and catalytic systems) and better lubricating properties that would contribute to fuel economies on a national level. As repair facilities, our members have two concerns with this issue. There is reason to believe that this new product may have a significant price increase which creates problems selling basic oil change service. The other concern has to do with “backward compatibility” of GF-4 oil. That is, can this oil be used in older vehicles once the GF-3 oil stocks are depleted without worrying about oil consumption because of viscosity changes? (If they are available, they will not have the sunburst logo and may not meet warranty requirements.) "
http://www.noln.net/columns/ch....html
"A recent class-action lawsuit brought forward by owners of certain 1998 through 2001 Mercedes-Benz vehicles claimed they weren't informed that synthetic motor oil was required in order to take advantage of the extended drain intervals afforded through the use of the vehicles' Flexible Service System (FSS). Many using conventional oils experienced premature wear problems, and the settlement will cost the company over $32 million.
"The long drain indicator used by Mercedes is predicated on using Mercedes-Benz-approved oil, which is a very top quality synthetic oil," explains the oil company source. "When those vehicles came to the States, somehow dealerships weren't impressing upon the consumer the need to use the right oil. "
