trpower7 »
https://forums.nicoclub.com/trpower7-u205.html
Sun Aug 03, 2003 11:18 am
That is very low mileage to be down a quart. I would suggest checking for leaks, as this is far more likely than the engine using that much oil. If in fact you can't find any leaks perform a compression test to check the status of your engine internals. At 56K I would be very surprised if your engine is using a quart between changes. At 165K my KA uses about 3/4 of a quart of heavy dyno oil, which I consider quite bad. Wait to determine the condition of your engine before switching to a synthetic, while I am a huge proponent of it, it will accellerate leaks in a worn engine.
