Oil question!
95zenki man
Is there any way to really tell if a car was run with synthetic oil or just plain ol oil?
The reason for my question is i just got a 05 350z a couple days ago and the dealership i bought the car at has no clue what was used in there. I am changing all the spark plug and oil and everything and I really don't want to screw anything up by using the wrong oil so dose anyone know any tricks to figuring out what was run before?
Thanks in advance for any help.
I figure i will post this in gin pop to get everyone in on the question and help. i know the Z section isnt very active right now.
Razi
Car: Moo
Use synthetic if you want.
There isn't a "wrong" oil.
I started using synthetic on my 240sx after I bought it with 160k miles on the clock.
No problems.
Pento240sx
Car: 1995 Nissan 240SX SE, 1981 Datsun 210 Deluxe, 1981 Datsun 810 Maxima Deluxe and 1999 Infiniti Q45t.
Just put synthetic, better for your car. But remember once you go synthetic you could never go back.
Dattebayo
I got yelled at and called a moron by Greg because I said the exact same thing. Don't believe it.
Razi
Car: Moo
You can go back to non-synthetic if you want.
Oatmealman
Car: 2011 ford f150 fx4 5.0 master race
Yes you can
i like to run blended synthetic before going up to full syn,or down to conventional oil
PEZi
Razi wrote:Use synthetic if you want.
No problems.
^ that
OriginalWheelman
Car: '15 Ford Focus Electric
I generally run synthetic in both my Civic and my Q45. In both cars I've been short on cash when it came time to change the oil and put conventional oil in. When It was time to change that, I went back to synthetic. Never had any problems.
95zenki man
Cool
Thanks for all the response. I was always told not to go back to conventional oil after using synthetic. i plan on running it anyway but i just wanted to make sure.
Do you think i should flush it anyway just to make sure?
Razi
Car: Moo
Synthetic+Regular oil blends are commonly sold, so I wouldn't worry about it.
Amays U G37S
Car: shoes
Lots of correct answers in here. You should run 50/50 convential and synthetic before you run full synthetic. My opinion, I would use Pennzoil convential. My father has used pennzoil since his car was brand new with 21 miles on it. The whole inside of the motor is a gold color all where the oil has been. Looks really cool and clean!
In that VQ you should go with what is recommended. Probably anything 5w-30. A tune up will really help with any problems. And if you have any leaky seals, running synthetic will make them leak more, of course! Just a heads up.
Post some car pics!!!!!!!!!!
95zenki man
Ill get them up in a day or 2,This rain has killed any motivation i have had for the past 2 or 3 days. hopefully this week will be nice and i can get out and wash her up and get some good pics.
got-me-a-z-today-t532496.html
alms24sebring
'04 Nissan Sentra SER SpecV
I always thought the myth was true. :couch
Amays U G37S wrote:And if you have any leaky seals, running synthetic will make them leak more, of course! Just a heads up.
Watsup with this then?
Razi
Car: Moo
Supposedly, the synthetic oil are better cleaners, and will clean the gunk that was clogging leaky cracks on bad seals.
I still went with synthetic, and slowly replaced all the seals that were bad since they are going to leak or leak worse down the road anyways, synthetic or not.
There aren't many things to leak on the KA, plus the seals are cheap.
Front main seal, rear main seal, oil pan, and the valve cover gasket is all I can think of, though I don't think the oil pans leaking are a common thing.
The rear main seal and the oil pan are the only tricky ones to get to.
95zenki man
Every seal on my old KA leaked.....and everything in the motor...
Razi
Car: Moo
:rotfl
Almost all the seals and gaskets are new on my motor.
No leaks ftw! :mike
95zenki man
Its not my problem anymore. ill let the guy that has it now do all that junk, a little smoke never really bothered me when i had my zenki.
:bigthumb:
alms24sebring
95zenki man wrote:Every seal on my old KA leaked.....and everything in the motor...
Yep! :gapteeth:
