Oil question
dbhittin
i have a 89 240sx se 5sp and the motor is a KA24DE i was wondering how much oil to put in when i change it, cause my dip stick is broken and i cant get a new one for a week. also what kind of oil is best for thses cars. thanks
drifts14x
Car: Cars, Motorcycles, Drifting
I put 4 quarts even into my car, if you are not in really cold weather or anything special, I would suggest 10w-40, as I used to use 10w-30, and the 30 didnt run as nicely as the 40 does. Just figured I could help you out(BTW, I used to own an 89 SOHC before my 92)
180fan
Car: 89 fastback
3.5L with new oil filter3.2L w/o new filter
remember to prep the filter element by rolling some oil in there before putting the new filter on.
I use Mobil 1 10w-30
bendychicken
Car: Racing, Pyrotechnics, Gardening(don't ask)
what happens if you don't prep the filter?:confused:
silviaNE
Car: cars what else?
you have a 89 with a dohc engine it it? did you swap the motor?
dbhittin
silviaNE wrote:you have a 89 with a dohc engine it it? did you swap the motor?
im new to these engine #'s, and always see the KA24DE, but i know its a S13 KA24 E, will go look at it soon. also, how do i make the tinking noise stop, it takes awhile so what kind of oil. its around 30 for the low and 40's high. here. thanks
Project_S13_180
Car: ya know
i just use 10w30 for both my cars and they run good
jjns13
I use 5w30 Mobil 1 in my 240 and grand am<--yeah I know, but the grand am is the sweetest car ever (cough,b*llsh*t,cough)
180fan
Car: 89 fastback
if you don't prep the filter element, it's not too good for your motor as it won't have the oil necessary to lube the parts of your engine as it's trying to saturate the oil filter while attempting to feed the rest of your internals. not too good for the engine.
Hijacker
Car: '92 240sx Convertible
'94 F-150
i'm sure your owner's manual will tell you all about what weight and how much oil to put in that car ;)
for the ticking noise, try putting some marvel mystery oil in your crank. it could also be injectors (i don't know if KA injectors tick like SR injectors do), so run some injector cleaner through it next time you fill up
