lucidd »
https://forums.nicoclub.com/lucidd-u85156.html
Wed Jul 30, 2008 8:35 pm
I'm no expert with oil...but Jacko is right about the viscosity... This 0w-20 spec may be too runny - or watery for the G [only because of recommended specs of: 5w-30].
Just fyi, which may shine some light on why this bottle would have the fuel economy green label:is probably because of the 0w<< this means that at cold temperatures [even below freezing point] this oil stays at a viscosity of 0w --- so it is excellent for cold temperature lubrication aspects... because the oil's lubrication at these low operating temperatures - protect as well as when the oil is at normal operating temperatures [after warmup].
So in essence - this oil with the 0w spec - will lubricate better* than a normal 5w oil <<<only at startup, and during warmup. BUT--- the problem is that after warmup, into the higher temperatures - such as a hot Cali day... ... with some flogging --- the engine/coolant/and oil temperature will climb - allowing the oil to become as viscous as water - which may affect its ability to protect your engine in this case.
--- like jacko said, the higher the number, the more heavier and thicker the oil is... which means that even at high operating temperatures, the oil will not become like water --- and continue to have optimal lubricating properties.
... at any rate ---IMO... I'd stick with 5w-30 mobil 1 -full synthetic - or royal purple... or whatever brand full synthetic.
*** claims of 1mpg better fuel eco - is most likely - 1mpg better over normal dino oils. .. I'd highly doubt 1mpg better over mobil 1 full synthetic 5w-30.
...Ps. Anyone try Duralube or Slick 50 or Prolong etc??
