Oil pump what is everyone else doing?
DammitBobby
Car: S13 91 KA24DET
Dam oil pumps are expensive!! I just wondering what everybody is doing? Is there such a thing as a performance oil pump or a way to increase the pressure on the stock oil pump?
Replace with a new one
Rebuild the old one
just have it checked
HolyShiznit
Car: Working on my car
*Looks at OEM oil pump on a turbocharged three year running engine*
That's what I am doing!
:: orion ::
Car: '96 240SX, with KA-T @ 12psi...
Stock here as well...~100,000 miles, seems to do fine pushing 10w30 Mobil 1.
For more pressure you can shim your stock pump...how, I dunno...having never done it. But I've heard of it being done.
- Brian
duncan351
Car: S14 KA-T
Very easy process:Unscrew the bolt next to the oil sump. Put two - three washer between the bolt and the spring.Screw the bolt back and that's it. Now the sping is compressed more making more pressure.
Duron
DammitBobby
Car: S13 91 KA24DET
Hmm, is this something you have all ready tried ? Thanks for the tip.
sunnys14
Car: S14
http://www.importperfomanceparts.net they have toga high volume oil pumps for the KA but i believe theyre on back order...
Import_Ant
I'm going to run an oil pump from an L28 turbo. (280z. it's a higher volume pump than the stock SOHC Ka oil pump)
DammitBobby
Car: S13 91 KA24DET
Sorry forgot to mention DE.
koukiKA240
Car: 1991 240sx KA-T
the toga pumps are on crazy backorder.
http://www.napa.com
i went to my local napa and got one in 2 days.~Sam
