Oil pump
eric96ser
Does anyone know what car uses the same oil pump as a DET? The valve cover is blue, but I'm not sure if its original. I don't drive a 240sx, this is for a mechanic friend. A tidbit of info in return for the answer to my question is that a 2000/2001 Sentra SE(SR20) uses the same head gasket as a RWD DET.
I H8 UR DSM
Here are a few US parts that fit the SR20DET engine:
Exhaust Manifold Gasket 91 B13 Sentra SE-R with 2 liter SR20DE T25 Turbo gaskets 95 300ZX TT T25 gaskets O2 sensor 87 300ZX Turbo Fuel Injectors 95 300ZX TT (purple plugs) MAF 89-90 SOHC 240SX, Stanza, Truck w/2.5 liter clutch 89 Nissan Maxima 240mm 9-7/16" spline 24x1 Belts (PS, AC, alt) Gates K050370 Alt. K040345 PS & AC Spark Plugs 91 B13 Sentra SE-R S14 SR Oil Filter 95 B14 Sentra SE-R S13 SR Oil Filter 91 B13 Sentra SE-R
: P
