Oil Pump
roast
Car: 1989 Silvia
I finished putting the motor back in the car, I did the head gasket, timing belt and water pump... Thinking the oil pump was solid (only 89,000km) I left it as my budget was tight for this repair. Low and behold, after 10km of less than spirited driving my oil dummy light came on and the car started making valvetrain noises. I promptly turned the car off and go a tow home... I removed the oil feed line, disconnected the ignitor and turned the car over to check for oil pressure... Nothing came out of the feed line. I then removed the oil filter, turned the car over and sitll no oil came out... for a sanity test, i drained the oil, tossed fresh oil in, turned it over... nada.
I need to remove my oil pan to check if my oil pickup is blocked, my thoughts are to lift the motor off the mounts, unbolt the lower bellhousing brackets, remove the oil return line and unbolt the pan.
Does anyone have a better idea for checking the oil pickup or an easier way to remove the pan?
Richard
float_6969
You can try to do it that way, but from my experience, it's a royal pain in the butt trying to bolt the pickup back on while you're messing with the oil pan. I always drop the subframe. It's really not that much work.
roast
Car: 1989 Silvia
float_6969 wrote:You can try to do it that way, but from my experience, it's a royal pain in the butt trying to bolt the pickup back on while you're messing with the oil pan. I always drop the subframe. It's really not that much work.
Thanks float... I never thought of that!
I will support the motor and drop the subframe/sway bar and support the steering rack.
Wicked idea! =D
float_6969
If you're doing this on a lift, build a support that goes across the engine bay with feet that rest on the edges of the engine bay, inside the fenders. Then have a chain that supports the motor.
If you're doing it on the ground, or jack stands, put something under the Transmission.
roast
Car: 1989 Silvia
I"ll be working on the ground with jack stands...
float_6969
I don't miss those days! Make friends with somebody with a shop that has a lift you can borrow on the weekends like me, lol!
roast
Car: 1989 Silvia
My brother has a shop but it's 45mins away... I had a USDM S13 w/CA18DET at his shop and it was a pain in the a** to travel 1.5hrs in total each day I wanted to work on the car... I work faster at my own pace on my own time =D
I'm winterizing the wrx and tdi this weekend, the silvia stay's idle for another week before i build my support and drop the front sub-frame.
ragenasian
Car: AE86 w/CA18DET
Build your own garage with lift, much easier :naughty:
roast
Car: 1989 Silvia
I own a bungalow (ranch) style house and don't have wide enough access to my backyard to build a garage! I'd love to build my own though!
I bought an electric two post lateral support hoist for my single car garage (it's tall enough) but didn't install it... It sat for a few years and I ended up selling it.
boost_boy
ragenasian wrote:Build your own garage with lift, much easier :naughty:
Nice!
roast
Car: 1989 Silvia
Gave the silvia a wash after winterizing the family mobiles...
float_6969
Looks good! I like the 2 tone.
@ ragenasian, You've done exactly as I'm planning on doing. Looks great!
roast
Car: 1989 Silvia
Reply to PM, hopefully he get's this message...
Azrial wrote:What is the paint code color for your car? The one as your avatar is the color I want to paint my vert I believe. Do you have any pictures uploaded so I can show my girlfriend.
Scott
See above pictures.... fix your PM's so you can receive messages and I'll send you pictures of the ID plate under the hood and in the door, they're in Japanese so you'll have to get it translated... edit: (see picture, it's in english, japanese...)
Azrial
Car: 93 240sx vert, 1990 pignose hatchback roller
roast wrote:Reply to PM, hopefully he get's this message...
Scott
Cool thanks for the reply I will try to fix them soon. I am headed out for work now. Sweet car.
