Oil Pump???
A forum for owners of S30 and S130 Datsun Z's... 240Z, 260Z, 280Z and 280ZX!
S130Z
Car: 1983 datsun 280zx turbo 2+2 1983 Datsun 280ZX-T*sold
Had it in once, forgot the gasket, and now i can't get it back in. The haynes book says #1 piston should be at TDC so i set it to TDC, and it still wont go in all the way, there is about a .5" gap.
Any trick or tip on getting it back in would be helpful.
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
guessing you forgot to remove the distributor? with the distributor otu and the engine at tdc, you align the oil pump driveshaft mark wiht th emark ont he oil pump shaft, slide the assembly up and in, then oout put the distributor on
S130Z
That's what i thought, but the first time we got it in the dizzy was still in.
But i'm going to take it off today and hopefully I will get it in.
S130Z
turns out the teeth on the dizzy are out of wack so that's why they wouldn't mate up.
so i have to buy a new dizzy, might as well get new oil pump/drive spindle while i'm at it.
anybody know of a good place to obtain these items??
I really am not looking to spend 200+ on a dizzy.
evildky
06 Nissan 350Z GT
ebay is your friend
S130Z
hahaha yeah that's where i was searching. I found the drive spindle for like 20 bucks, but still no luck with dizzy.
Might just have to drop a couple hundo on a new one. At least i will know it i will work.
Return to “Datsun Z Forum”
