Chris28 »
https://forums.nicoclub.com/chris28-u70836.html
Tue Feb 10, 2009 12:31 pm
So while swapping a new KA in last weekend I got to thinking why my old KA failed. I'm almost positive I put the rods back in not only the wrong way, but also with the wrong end caps on them.
What seems odd to me is that I got rod knock so quickly on brand new bearings, not to mention I know I torqued everything down to spec.
Also, the turbo was knocking/hitting the compressor housing. When I took the engine out I felt the turbo, and there is maybe a mm at most of side to side shaft play, nothing in and out. Turbos don't just knock like that, something had to be wrong...maybe it wasn't being lubricated.
Let's say the oil pump was defective. That means the rod bearings weren't getting any oil, as well as the turbo not getting any oil, resulting in both "knocking." I didn't have my oil pressure gauge hooked up so I don't know exactly what was going on, but it seems really odd that the 2 things that need oil seemed to fail, and it was a brand new oil pump that I didn't know worked. I know my old stock one worked because the engine ran well with it.
Do oil pumps need to be primed? I'm just wondering if maybe it was something else other than me putting it back together wrong.
I know this seems like beating a dead horse, but I'm starting to wonder if maybe it wasn't totally my fault for a crappy rebuild.
