oil pump????
A forum for owners and fans of the legendary Nissan Skyline and Nissan GTR.
SgtRC
Car: 1991 nissan skyline GTS-t Type-M
Ok, i am thinking my oil pump is going out!!!yeah i am alittle timmid right now!! It seems to build oil pressure kinda slow and when it starts sometimes it sounds like a dog bark. kinda weird uh??Were is a good cheap place to get a oil pump at and how much of a pain in the arse am i about to get into?is there anything else i need to replace while i am in there??i know i need to get a oil pan gasket and of corse a oil filter and i think thats it!
cbileske
Car: 1992 Nissan Skyline GTR
ahh man your in the same boat i am. A decent oil pump is about 1000 dollars, and you might as well get a new oil pan baffle since it will aide your engine. you can get cheap pumps but this will probbly happen again. I have been told that the best way to change the pump is to pull the engine. I am almost done pulling the engine right now. Check your turbos, if they had a shortage of oil there is a chance they are worn now. Since i have my engine out i am replacing all the bearings, gonna check the pistons and rods, all the gaskets and seals, metal head gasket, soo on.. http://www.RHDjapan.com seems to have pretty good prices or if you want stock you can find it on ebay cheap.
SgtRC
i guess its not going to be cheap like i was hopeing kinda figuredmy buddy was telling me i may have a bad gauge, he said its a commin misperception that if the stock gauge is reading inconsistant that the oil pump is going.so i am going to get a aftermarket one and hook that up first to see i will keep you posted as to what i find out
cbileske
good plan dont let it run too much if your not sure tho. dont want to cook anything. I hope i dont see anything wrong i didnt know of when i take my engine apart.
SgtRC
ok well heres the latest and greatest on my oil pump:my stock oil gauge is inconsistant with my aftermarket one and the noise i am hearing is my stupid altinater and its lack of bearings hahai got a used alt and a new belt so i am fixing the noise.. i have to find a mount for the oil press gauge haha its kinda hanging out in the passenger seat right now but i will find a mount someday!!
cbileske
thats not bad at all then, i found my problem and it is the #2 connecting rod...
SgtRC
eek sorry to hear that man did it do alot of damage?
themadscientist
christ man that car is giving you a buttload of trouble.
cbileske
yah no kidding. Well the crank looks pretty good as far as i can tell, the bearings took the abuse, all the connecting rods look good, pistons have some scaring on the top sides nothing bad, and it looks like there was some dirt in the cylinders, honing them will clean up at leat 5 of them, can you bore a minimal amount out of the sleeves? like 10 thou or something very small? if needed. The turbos also have side to side play not alot but a little so they are being replaced and the cams need to be machined but the head looks good, i will have it pressure tested. the oil pump is good but u can see where the crank was hittin and where failure would result eventually. so my next step is taking the crank the bare block and the head over to the machine shop across the road from my shop and see what they say. I used http://www.Rhdjapan.com and had my engine gasket set in 3 days to canada. i figured i would order something small and cheaper first to test em out.
Return to “GTR Forum / Skyline Forum”
