Carkeeper »
https://forums.nicoclub.com/carkeeper-u48701.html
Mon Sep 24, 2007 11:37 am
You will want an R33 or R34 crank and preferably an R34 Damper.
ALSO: DO NOT use an N1 pump, they will break. Use a JUN[about $1000] or a TOMEI[about $1200].
There have been a rash of N1 pumps fail in the past 6 to 9 months, we suspect a bad batch from NISSAN.
N1 are made of "powered" metal; the JUN and TOMEI are made of Chrome Molly and have secondary machine operations in the corners where the stesss is bulit up on the pump to crank interface.
I had to replace mine, when it broke, wasn't under boost and noticed it immediately, fortunately not breaking the engine, other weren't so lucky.
Don't save $600 to $800[on the weakest link in the RB26] on a $15K engine.
Modified by Carkeeper at 2:50 PM 9/24/2007
