oil pump removal
zombieslider
sounds dumb but how do i get it off? Im having trouble trying to get this off
fsm just says take it off no insight
also tryed searching on here and came up empty handed
rico05
Car: 1992 RMS13 w/ CA18DET
You need to get the crank sprocket off. Some can get it off with a pair of screwdrivers. Some need to cut and use a chisel to break it. Some heat it and beat it off.
zombieslider
if i break it where do i get a new one?
is there a way to use a puller
wait break the pump or the sprocket
rico05
The sprocket. You get a new one at the dealership. I would try heating it with a torch from the parts store and using a 3 jaw gear puller.
Do a search for "crank sprocket" or "crank gear".
zombieslider
it just seems like over kill to break the sprocket, the problem with using a 3 leg puller is the "hood" on the oil pump keeps you from getting the one leg on the top
zombieslider
i got it off with some good ole american muscle, not mine of course im skinny and lazy
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
A two-leg puller is a good choice to start with. Put the bolt in the nose of the crank so the puller has something to work against. You will soon find out what you are working with.
float_6969
It's pretty common for them to rust themselves to the crank. You'll either want to drill and tap holes in it and build a plate that will let you pull it off that way, or you'll have to try to cut it and chisel it off.
zombieslider
i got it off already, used a hammer and some pry bars
Fleemer
Car: Pulsar Exa, FC3S
heat it up, soak in in wd40/liquid wrench.
try and pry off
repeat until off.
In the case of a 200k+ motor, its rusted on, cut it off :P
slo325i
Car: 87 327i, 92 240sx
I've worked on 3 ca's so far and all of the crank sprockets were removed by hand.... I guess i just got lucky...
Also, are you removing just the oil pump while the motor's still in the car?? Have you removed the pan yet??
zombieslider
******I got it off already****************
i just used something similar to wd40 and a hammer some pry bars. But it was out of the car so i didnt have the trouble of the car being in the way
float_6969
I'm gonna lock this, just because ppl don't read and keep posting.
