oil pump rebuild
lenso
Car: 1993 240sx hatch
i ordered the gears to rebuild my oil pump from heavythrottle and they should be arriving in a few days. then i thought about gaskets and such. what gaskets/seals do i need to replace if any? i searched but came up empty. all i found was suggestion to replace the entire front cover. nothing really on rebuilding.
180fan
Car: 89 fastback
no real gaskets but aside from gears theres also a spring
SpeedRacer1
Car: 1990 240SX, G35
You will need to re-liquid gasket the oil pump back on. And you will also need a new front main seal, use the Sentra SR20DE part fot that.
Hijacker
Car: '92 240sx Convertible
'94 F-150
speed doesn't mean to use LG on the pump cover itself, but instead the front timing cover.
And it's been my experience in the past when you pull the front cover, you should consider pulling the whole lower pan. When you break the seal of the front cover, you can't just put it back in. There will forever be a small break in the gasket which will cause leaks.
lenso
SpeedRacer1 wrote:You will need to re-liquid gasket the oil pump back on. And you will also need a new front main seal, use the Sentra SR20DE part fot that.
crap so i do need a front main seal. i'm guessing a 93 sentra se-r front main seal from autozone will do?
xsblacksx
man just buy one for your model they are cheap chaap
Henry G
Do a writeup on how to do this.
