oil pump question
Asia989
Car: 90 s13.4
Seeing i rod knocked my motor due to inconsistent oil changes and replaced the crank an bearings do you think the oil pump is still good to use?
Justin35ll
Car: s13 coupe sr20det
How did you get a rod knock from "inconsistant oil changes"
Asia989
Car: 90 s13.4
Justin35ll wrote:How did you get a rod knock from "inconsistant oil changes"
not changing the oil for 12month periods
OM3GA
Car: A Sexy Mobile, 1993 Nissan 240sx 180sx Hatcher
Bullfrogg0
Car: 1989 Nissan 240sx
if i were you since you got bearing material into the oiling system i would replace the oil pump because the pump housing is aluminum and when you introduce something harder than aluminum into tight tolerances you will quickly wear it out. you might get away with not having to replace the pump but then again you might have good pressure for a while then poof, motor is garbage again. i'm in the middle of a build due to a rod knock and i'm not gonna attempt to re-use the pump because i'm not about to chance wasting new performance pistons and rods cuz i wanted to save $200
Asia989
Car: 90 s13.4
Bullfrogg0 wrote:if i were you since you got bearing material into the oiling system i would replace the oil pump because the pump housing is aluminum and when you introduce something harder than aluminum into tight tolerances you will quickly wear it out. you might get away with not having to replace the pump but then again you might have good pressure for a while then poof, motor is garbage again. i'm in the middle of a build due to a rod knock and i'm not gonna attempt to re-use the pump because i'm not about to chance wasting new performance pistons and rods cuz i wanted to save $200
thats the kinda answer i was lookin for lol, the wife went ahead and ordered me a new one, now i gotta disassemble the bottom again to instal it
supreamS14
Car: 96 240sx S13-blacktop Sr20deT
I had light rod knock for months, had the crank polished and its good. Now a spun bearing is a different story.
Steady_One_S13
Car: 1991 SR'd 240sx S13, 1993 Toyota SW21 Mr2...
Asia989 wrote:not changing the oil for 12month periods
wowzers. lack of oil changes can do that??
Asia989
Car: 90 s13.4
yes it can, lack of oil changes+8500 rpm bouncing is disaster waiting to happen
Steady_One_S13
oof...
My SR is due up for an oil change.
